21 - 40 of 109 Posts
I havent seen any cast manifold with low boost crack........................
But your a big boy and big baller. It's your money and your car.
Discussion starter · #23 ·
Is there any specific ecu I should buy I have seen p06 and p28 on ebay. Is it worth it to buy a chipped one or should I put a socket on myself? I can solder but never tried on something like this I have to led stuff in xboxes
Thats a hard call. If u got the skill I would get a cheap p06 and convert it to vtec and socket it.
If ur skills r lacking the get a p28 and chip it.
Now if u have no skills and money to burn then order a chipped ecu with a base map from one of are sponsrs.
Xbox and leds r a little different then the ecu. U have to desolder some stuff.
Discussion starter · #25 ·
Ya I have never desoldered anything but I'm sure I could do it just don't know if I trust myself plus I don't have a good iron.ok who would I look for to order one chipped from here. Parts should start arriving all this week can't wait
Discussion starter · #27 ·
Ok I'm having troubles figuring out what I need for my oil and water lines for my turbo there's one on go go autoworks but its for a gt bb turbo and its 260$ where exactly should I buy it from and are the oil and waterlines the same?
If u got the oem replacement nissan t25 then check first page of my build.
But from what I remeber the feed is a 11m 1. Something. Drain is 44mm bolt spacing. Coolant lines are 14x1.5mm I believe.
But im on my cell so check my build n when I get home ill get u all the sizes.
Fyi I paid around $15-$20 for each item mins lines/hoses
Correct sizes below
please post where you got them i'm having the same issue with finding stuff for my t28
yeah don't try to chip it yourself its harder than it seems i've done xbox stuff and tons of wiring without proper tools its pretty hard, the chipped ones from that place are real good i have a p06 from there
Ok im home now and i check my list
For my oem sr20 t25 turbo these are the sizes:
oil feed M12x1.24 4an 1.5mm restrictor I got a banjo bolt
Oil Drain flange 44mm bolt spacing 8an
Coolant thread size M14x1.5
I order them from ebay Authentic-Boost
prices are fair and shipping is ok. He might not tell you that your order has been shipped but within a from order date your have it.
I have a tap n die kit so i used that to find out the sizes of the threads before i ordered.
On the ecu its not to hard but then again i solder to ic chip legs that are as thick as a hair.
This was for a digital keypad lock
but i have soldered to things smaller. wii ic chips, ps2 traces etc..
Discussion starter · #32 ·
Thanks everyone's has been a lot of help I will look on eBay again here in a little. I should get my ramhorn and fmic today so I will have pictures tomorrow probably
Here's my fmic and turbo. still waiting on my manifold it keeps getting delayed
fixed your pix for you
you have to right click on the pix then copy image location.
And thats the same turbo i got in my build. I just redid my downpipe today for a better fit.
Discussion starter · #38 · (Edited)
Thanks man I do everything from my phone cause I don't have internet so I wasn't sure if it was my phone being gay or I screwed it up.
What does everyone think about an oil sandwich adapter plate I have been thinking about going that route but heard that they leak
Been running a sandwhich plate for about 5months now without problem. I have a 4an line that run to a 4in flare with gauge mount for my oil psi gauge.
Also had a sandwhich plate on my del sol for oil psi and never leaked in the 3yrs i had the car.
IMO they are the best route because you wont get a fitting broken off in your motor and easy to install and remove.
Discussion starter · #40 ·
What brand would you suggest I was reading some give filtered oil to the turbo and some don't. I'm sure its not a big deal anyways if you change the oil often
