Meziere Electric Water Pump
9.4K views 20 replies 10 participants last post by  l337h4l
#1 · (Edited)
I had to do a new Timing belt water pump tensioner anyways. So I found Meziere. I remember back in the day when AEBS brought these out I was building a sleeved stroked B18 to 2.1ltr until IHRA outlawed deck plates over .500" Grrrr. I still have the Crower rods to make a 95mm stroke 1.75:1 RS ratio. Anyhow I picked up a used one on Hatertech for $200.
No install instructions but pretty straight forward.
I know its not a D but here are some pics.
Only downfall is you have to remove the hook where you attach an engine hoist to the transmission...
Installing the Pump Bracket in its place
Pump installed
After I got it together I put new stainless clamps on it to make it look cleaner.
Pulley installed
Comparison of pulleys:
Install was easy I still need to wire the pump into a relay for 12vt switched so I do not need a switch on the dashboard. as well as modify the thermostat with 2 4mm holes.
I like how it turned out BUT its about a 1/4 of an inch away from the spark plug on the distributor which I DO NOT like and its a tight fit..
The mounting plate should had moved the pump further forward to keep it off the distributor.
The Whale penis is basically jammed between the pump and the shock tower... Not the pumps fault.
Over all easy install I also tossed on a new tensioner/spring and Gates timing belt.
I will say the gates belt is much more stiff than a OEM belt and I think that it should hold up much better to the 9250RPM I have on the engine. OEM belts were stretching out over 10k miles.
#2 ·
very nice product and install man!
reducing parasitic loss is a great thing
how much $$ and how much power? haha
#3 ·
Picked it up used for $200 New they are $400 Meziere says 3-7 HP since the motor already makes 238WHP I would hope its a 7HP gain but who knows the motor is getting torn apart I think a head stud stripped and blew a HG after i got it together.
Redline of the engine is 9250 so a regular water pump has cavitation at high RPM. Not to mention the last Type R pump only lasted about 25k miles before the bearing failed and started to squeal.
#4 ·
Just wondering, wouldn't it be better to put the pump on the back of the motor(between the original water pump and t-stat)? That way, it's not pushing against the T-stat and would still circulate fluid in the engine even though the t-stat is closed.
#6 ·
I really wish they made a block off plate for the D series. I need one of these.
#8 ·
just cut the stock water pump impellers or w/e they are called
#11 ·
The water pump/idler pulley setup they have. I would need one of those. Or as mentioned, I guess I could try and cut the impellers off.
#9 ·
Wouldn't the only difference between this and a d-series would be the radiator hose sizes (which it looks like you can change out the fittings on the pump) and the water pump replacement being different? I always wanted to do a electric water pump setup, mainly because you can use the pump to adjust the water temp (just remove the thermostat) by turning it up or down (I've seen some that have speed control, but that one looks like it's just on or off).
#10 ·
You can have the pump go too fast as well.
If the coolant is moving through all the ports too fast to pick up any heat so the water temp may be lower but the heat is staying in the block.
#13 ·
Not true. You can get more consistant temp control
#12 ·
Yeah just cut them off with a small dremel wheel, make sure to smooth it all out and I see no reason to have a dummy pump made by them since a stock one is more then enough to just hold belt tension.
Wonder how much power this would gain on a stock-ish d.....prob not enough to warrant the money haha
#14 ·
Prolly comparable to removing the Ac or Ps or maybe less
#17 ·
I know this but since I just pulled the $7000 Engine apart because it over heated and warped the block .005" and the head .003" I did not feel like worrying about climbing temps. Car is only driven in the summer anyhow not normally in cold crappy rain.
Engine was in pieces last Tuesday assembled Wednesday 20 min. break in Thursday and a 325Mile road trip Friday morning. I was being Over cautious on temps
#18 ·
Keeping the engine too cold is just as bad. If you still have problems with maintaining operating temps, try rerouting the pump(maybe grab a spare waterneck to do this) so that it is between the old waterpump and thermostat. This will allow you to use a stock thermostat and you don't need PWM control or possibly even a restrictor.
