161 - 180 of 819 Posts
Man I'm down on weight huge since I started being a Mechanic.
From like 190lbs to 140lbs. Insane transition.
Way stronger, but way less weight to throw around. lol!! The F22 weights more than I do, I can tell.
If it didnt have to come down a flight of stairs, I would find a way... wrangle it on a skateboard or something... but if I try this solo, its asking for pain and damage. LOL!!
that bitch was fucking heavy.
Bunch of light weights!
I dead lifted and carried mine 50ft and onto the back of a pick up. Then another 30ft after....
Do work!
why, hello there lol
Reactions: jvtec8k and FarmerD
Discussion starter · #166 ·
Mine got delivered and I pulled it off the truck with a hoist. Work smarter, not harder!
This!!!
Haha that blow up of me is funny, especially with the other pic of me when I was fatter! haha.
This is why I bought a lift from HF a few years back. Makes it easy.
Discussion starter · #171 ·
Should we tell it'd been easier to take the cylinder head off before moving it? I'd do that, then torque the head on after the block was in the car. The F22 is like a sohc D16 where you can leave the cam in to torque the head studs.
This is my plan to get it back up the stairs. Lol.
Especially if I delete the balance shafts, and now that the block has no coolant or oil in it, no alternator, and no RETARDEDLY HUGE intake manifold, I bet its lost a solid 30 pounds already. haha.
Very clean in these ports considering it has 300,000km on its clock! Perhaps its been opened up since then?? :D
That has to have been cleaned at some point. I got almost 200k on mine and I get so much oil sucked in from the pcv system. Can't wait till tax time to do a catch can and pcv delete. Along with at least a refresh of the head.
Discussion starter · #174 ·
Exhaust valves have some build up on them, but I'll take care of it. Chances are the head will need guides, but oh well, it will be worth it to rebuild the head properly.
Do work! I remember doing valve job inside my room fun stuff :clown:
after reading and reading then reading some more not to shit on the work you've done at all
If anyone in this forum would or could build a g23 it would be Mr Danz
Please with a cherry
If you are looking for a build thread for a g23. There is a link to mine in my signature.
Farmer d its looking good keep up the good work
Discussion starter · #180 ·
Its really not a bad idea. But if I was going to build a bottom end, I would probably stick with the F22 bottom end, overbore, and go with some 11:1 CR pistons.
I think I will hit 180whp with this setup. Maybe more.
