21 - 40 of 534 Posts
hands down suncribed more pic fooooo
Reactions: sql_civic
Really nice work Carl. You have definitely done your homework on this build. I'm going to have read through it a few more times to absorb everything that you've done, but way to innovate one helluva a frankenstein build.
Discussion starter · #25 ·
Thanks
Thank you all for the kind remarks. Just to set the record straight, I don't really think I've invented this combo. There are a few other stroked D16s out there but they are rare. 78mm D16 are out there as well but also rare. As we all know Pearl's build is essentially the same as mine but with some interesting variations. Unfortunately we won't be able to learn from each other's mistakes since we'll be making them at about the same time. ;-)
I am much further along than the thread leads you to believe. It will take me a few days of nightly updates to get current.
well if anyone has been paying attention to your posts when a stroked d16 comes up, they would know. or if they looked at your other d18 thread. i am waiting for you and pearl to finish, so i can be corrected in my belief that a d18 is just a dream engine.
Assuming no more problems, mine should be running with low boost in a month.
let me know bro, i'll definately roll down the "hill" and see this happen. :TU:
i'm in and subscribed. a torquey D-series might no longer be a oxymoron.
Discussion starter · #30 · (Edited)
A close look at the guts
Sorry, I didn't get a chance to post up another intallament last night. I spent 2 hours on the car and then got caught up in Game 5 of the Stanley Cup finals. But here goes...
Here's some close up shots of the assmbled rotating assembly (sounds redundant, huh?). Note the slight amount of block notching that's normally required for wider aftermarket rods. In addition, the main cap had to be notched to accomodate the wider swing of the crank. Both areas would still need to have been notched even with OEM rods because of the longer stroke.
Both the block and main cap notches can be seen in this shot.
The rods came with ARP rod bolts. And speaking of bolts, I briefly thought about using ARP main cap bolts or studs. I guess I figured on sparing no expense at building a strong engine and bolts are generally not that expensive. Anyone ever heard of man cap bolts failing? A friend of Mike Belben told me he used ARP main studs and it may have contributed to distorting the main bore. He says that he's heard of guys using H22 studs but you can't. So I ended up re-using the Y8 main cap bolts on Ken's advice. I know the re-use of main cap bolts has been recently discussed here in another thread. And BTW you can use the bolts from either the Y8 or D17. The D17 main cap fits the Y8 block also but the bore will be misaligned (unless you're lucky). It might be correctable with an alignment bore if it's close to spec.
Here's a shot of the machine that Ken presumably used for the notch work. I'm sure it does a much nicer job than me and my Dremel. I may have had trouble grinding into the iron sleeve. (For the n00bs: that's not a d-series block.)
This evening my 11 year-old daugher has a softball game so by the time we're done with that I'll be too bushed to work on the stroker. Instead I'll post more photos and rep all who have posted in the thread so far.
wow, a milling center for notching? thats pretty sweet, maybe overkill but still
Mike does things that way :)
I miss his knowledge on TOO BBS.....it was great place to learn, helped me alot.
Discussion starter · #35 · (Edited)
Prepping the motor
Before this motor goes in the car, I need to clean it up some. The machine shop had hot tanked it twice and brushed it off by hand a little but it really didn't look that sharp. Ken wasn't a believer in bead blasting blocks because of the risk of having a small particle get inside somewhere and mess things up. His shop is looking into a salt based method that doesn't have that risk - any leftover salt just dissolves.
Now some of you may have bought parts from me so you may know that I like clean parts. It probably came from working on so many greasy engines over the years. Since I wanted to get the hang of painting and polishing parts I basically try to prepare every part I sell as if I was going to use it myself. Here's a pic of a Y7 IM I cleaned up and sold on eBay.
In this part of the country your engine will eventually look like shit if you drive your car year round. So if I polished the block, eventually it'll get coated with salt and develop a layer of aluminum oxide (rust). So in order to have any chance at keeping the engine looking good over time, I decided to paint it. It's easier to touch it up with paint than to try and get a polisher in the engine bay. Besides, my EX tranny was already painted.
So I masked off the top of the block, bolted on an oil pan, plugged every hole, and proceeded to clean off the block with various wire brushes of every size. I used the dremel to get into the tight spots. Here's a couple of shots after it has been brushed clean. After wiping it down with acetone it was ready for paint.
I stuck some old bolts in the holes to keep the paint out.
Front view. There's some exposed metal on the front that the timing belt cover doesn't hide to that got prepped and painted as well.
I used high temp VHT Aluminum paint. No primer. Here it is after being painted.
There shouldn't be any problem using that oil pan, ya think? (It's from a D17)
OK now as promised I'm gonna rep all who chimed in so far...
Discussion starter · #37 ·
Quite a guy
Mike is quite a bright guy. He's invented a cam profiler (I think) that might make it into the Skunk2 catalog if it hasn't already.
Hey SQL, my D17 valve cover came today... A nice big evacuation port right in the middle of the cover. It's just begging for COP too... ;-)
That is some seriously clean parts. I'm the kind of guy who usually lets things be if it works lol. maybe i should start taking care of my engines appearance too (you would hate to see my engine bay lol)
