D16A6 all motor
11K views 30 replies 22 participants last post by  Nasty_Canasta
#1 · (Edited)
My name is Zing and here is my non-VTEC SOHC.
One for the search engine.
Special thanks to :
  • Pat of RDR for the head work
  • Chris @ MAP for Dyno after Dark
  • Jordan for making what I put together sing in harmony
  • my good friend, Charlie Moua for the pretty valve cover
  • GreaseMonkey and Wil at Exo <-- almost forgot
The setup:
D16A6
Z6 intake manifold
RDR - slight porting with 5-angle valve job
Bisi valvesprings + stock retainers
Exospeed stg 2 cam
PM3 oversized pistons
ARP rod bolts
ACL race bearing
Edlebrock header
Kteller 2.5" weld-ur-self exhaust kit w/ Magnaflow
P28 Crome
Jordan Tuned @ MAP
This is just a repost of my original thread from the local site in MN. Thought I should share it with the D-Community too.
#5 ·
Nice vtec burner, nice.
good numbers also.
why not just use the NPR p29's or the pistons from the ZC?
#8 ·
Money spent on this was approx 2500. Car was 600.
There may be some restriction in the choice of header but got very lazy after the dyno. Haven't even washed my car since then (march)
FYI the motor did not like being advanced by 2. Lost 3 ponies and some trq.
Have not tried retarding it, should have done it on the dyno.
But as soon as Exo's stg 3 gets to me, another session and hopefully there will be enough time to try out different settings on the cam.
The plan was to squeeze some giggle juice that's why I picked the pm3 over the p29. But garage got broken into and the tank got stolen. Lost motivation when thinking back about the p29s.
This build has been very educational for the price. I've learned a lot from this little motor.
This is my first SOHC build.
#11 ·
mid range torque is alright, to make it last though, beaves suggestion sounds right.
a longer tube will help accomplish that? sounds almost too easy.
yeah if advancing it isnt the answer, then be cautious about retarding to far also. otherwise it should work.
#12 ·
I dont think cam timing will help, just hurt, from how short the peak is.
the intake pipe has already proven itself so im sure it will help as beave said.
but power is about right, I like and thats what I would assume.
Im diggin this car, remnds me of mine, nonvtec power fo sho!
#22 ·
we have talked about the possibilities of squeezing more out of this cam because there is some more to be had. but im sure this was a learning process anyway which i know the new stage 3 cam will appreciate.
#24 · (Edited)
doing a similar build right now ...D16 A6 ...........in ciollecting parts phase
block decked....head shaved........pm6 pistons .50 over........head 3 angle valve job....springs( not sure yet what to get???)....... intake is a z6.............head and intake gasket matched ported.....( not sure about polishing ...hearing diffeent opinons on fuel molecculizing)......colt 278 cam.....TB stock and port match....will bring it from 57 mm...to like 59mm..........getting injectors cleaned and balanced........8 pound fly wheel stage 2 clutch..........i did a moose mod y8 manifold ( look it up on here)....2,5 inches all the way back......wide open muffler no cat...........any thing i am missing?????........oh btw...this is for an oval racer that is supposed to remain stock......any guesses on what HP will be....I have no clue
#25 ·
a tune is my best guess.
