I just got this working today and it's slicker than shit. I've had a Sparkfun Bluesmirf (BT uart modem, similar to the Moates BT module) for a while that I got working last night, then I saw this app this morning. One of the easiest $5 I've tossed at an app.
First you install it, then w/in the app you choose the protocol you'll be using (Crome, ectune, Neptune, and even Moates Quarterhorse for V8's). Get your bluetooth module paired with your phone, turn on the key, then select that device w/in the settings menu. Make sure it shows "connected to ecu". It initially didn't want to play nice, but after bouncing between screens it decided to connect properly. One thing I've noticed is it will disconnect when you go to the main screen, but will auto-reconnect in a fraction of a second if you have auto-connect enabled.
You can choose many options for gague display, although I'm hoping for more options regarding different Units (in.Hg) and gauge limits. Response lightning-fast, and it has all the important datalogging data available. For eCtune there are several "none" fields, so I'd guess those are some of the dozens of benign eCtune data such as EBC on/off, brake light switch status, etc.
The playback is painless and can be paused, but there is no time index displayed nor any rewind/fastforward. There is an option to record a video that overlays the data on the screen, but I can't get mine to work. It makes a ding when I start and stop recording, but I can't find the video anywhere. It may be phone-related settings since you can adjust video size. It does record the datalog file, but the gauges freak out after a while if it was recorded in video mode.
Overall I give it 4.5 stars. :bigok:
It's still in beta form but few if any bugs remain. I'll upgrade to 5 stars if I can get video to work.
https://play.google.com/store/apps/details?id=com.linszter.tunerview
