Really? Compression is one of the factors that affects cylinder filling and in turn, volumetric efficiency. The better the VE, the faster the turbo will spool. Also, higher static compression generally increases the velocity of the exhuast gases, which will help spool the turbine faster.
Have you driven a very low compression setup? (Anything less than 8.5ish:1) It sucks. The power delivery, as I have noted is very disconcerting and not smooth or easy to tune at all. To contrast that, a ZC engine with stock internals running at 9.5:1 can spool a regular T25 to 8 PSI at 2500 RPM with a good exhuast. If you dropped the compression, the car would not be able to accelerate the mass of the turbine as effectively because you are simply loosing mechanical advantage, and thermodynamically, because your exhast gasses will generally have less velocity and heat to accelerate the rotating mass of the turbo.
Also, the difference in spool times between a 9:1 compression engine and a 10:1 compression engine is not the same comparison as between an 8:1 engine and a 9:1 compression. Yes, they are numerically higher, but the thermodynamic effects are not directly proportional. If you had a 6:1 compression engine and a 16:1 compression engine, the power outputs would not be 10 times the other.
So, how do you back up what you say? I have riden and driven cars with low compression set up to boost high PSI. Once the turbo spools, it's great, but getting them to spool takes more time. If I had the time and money, I'd build an engine with low compression pistons, tune it, dyno it, and gather data on spool times, then put in higher compression pistons and do the same thing. Unfortuneately, I don't have the resources available to do that.
