I have a firm understanding off how Baro pressure is used in reference to your tune when it comes to MegaSquirt.
But on OBD1 Im still not sure.
So most ECUs i.e. OBD1 and Mega have either a Dual Port Map sensor or a separate sensor to measure Baro. Baro will be based on your elevation.
So say for me my baro is 910 for somebody near the sea its probably much more maybe 1013.25 Mbar.
I can see that the Honda ECU has a Sensor to measure baro.
How is this reading used in conjunction with the maps.
i.e. say I create a tune at Sea Level. How will it run at 5000 Ft ?
i.e. how are the numbers from the Baro sensor used ? If at all on obd1
