Archived.
I suppose there may have been another way to prevent additional movement, but I wanted to delete the valve body completely. There's really no use for it once the pump has been removed and since it's just dead weight and the block plate was easy to fab I figured this would be the best bet.instead of fabbing a blockoff plate, couldn't you drill two holes from the case edges and use two parallel bolts to create a channel trapping the pin? I feel like that'd be easier than fabbing a plate
I know. You posed that link already on the first page. As I mentioned then, this link doesn't remotely address what I wanted to accomplish with this rack. Thanks for trying to be helpful though.
Yikes!Be sure to check the tie rods boots and replace them if they have any cracks/rips...
Don't buy from a place that charges a coreawesome write up, gonna give it a try over the winter seeing as no one will take a p/s rack back for a core when buying a manual rack
So swapping an integra rack and just loop it or???Update:
After 2 full integra racks and much debate with Biggie.
We found out that the integra racks don't have this valve body guide setup. And has zero play powered or not.
So if you don't want to play with this setup, find an integra rack.
Maybe I'll get biggie to post up a video also.
He did a write up, right? Time to go searching! MahalosWe are (well, Biggie did) cutting the piston. But yes, just a loop on the integra racks.
