I have posted on here recently about oil pressure problems and got alot of pointers and got that problem solved. Would like to try again with my latest problem.
Check engine light, whatever code is for Vehicle Speed Sensor (17 I think).
The car is a 91 CRX HF with D16A6 swap but, people will hate me for this, with the HF manual transmission. The car runs, but like crap until it warms up to temperature and then the check engine light kicks on. Then the car is pretty amazing. It stutters really bad and barely moves until up over 2000 RPM, then it moves. I end up driving in 3rd gear til the light comes on then I can go to 5th.
Once the light comes on, the car moves. Took it up to 80 mph in 2nd gear, was kinda fun. It runs fine with the light on which makes no sense to me, no stutters or power problems.
Today I made sure the cable was in all the way, and it is. The speedo works, tach works as far as I know. However after me checking the cable it likes to claim I idle at 0 RPMs, so it's a bit off lol.
Question is, do I just need to replace the sensor and will that solve the problems. Or does anyone think there are other issues. Also what is the redline, I have taken it up to 7000 RPM without hitting rev limiter.
Thanks in advance.
Thanks in advance.
