Last year I purchased a 96 civic hb OBD2. well I am a noob and did not know to much about honda engines so I let time pass while there was so many engine codes coming from the ecu, I was told it was because the vtec solenoid was not connected. A week ago I started cleaning the tb,manifold etc and notice the car ran better. So I told my self what the hell lets look at a few forums and see what it would take to run vtec solenoid lines to the ecu. And this is what slapped me in the face.
Engine: jdm D15b vtec head on a D16z6 vtec block, Head is stamped P08-2 OBD1.
d16z6 dizzy with some crazy wire conversion that is not done right OBD1.
obd2 wire harness I do not know what car it came from.
OBD2 ECU P2E.
Y7 intake manifold the one that looks like a spider up side down.
The valve cover gasket are stripped should be fix tomorrow with Heli coil.
The exhaust manifold has that crazy looking catalytic converter on the top with the 2 o2 sensors and its a bit ruffed up.
Also has a cut off switch, Witch I have no use for.
I have my work cut out, so how do I get the vtec to work and what parts do I need to buy to make it work.
What ecu do I need to run with said wire harness I am not sure this is the solenoid for this engine.
Please help this noob lol.
OBD2 ECU P2E.
