auto vs manual trans cooler?
1 reading
2.4K views 7 replies 5 participants last post by  secretd16turbo
#1 ·
i've been digging around looking for transmission coolers on the interwebs. i was on summitracing.com and saw that they had transmission coolers for manuals and automatics. does it matter which one i get? the manual version seems to be cheaper. also in some of the posts i searched thru here and there were some available from the local auto parts store (pepboys, strauss, autozone, advanced auto). anyone have any part numbers? recommendation on core sizes? mounting locations?
i need to keep the auto tranny in shape while i save up money.
#6 ·
ALL automatic trannys come from the factory with a cooler, it's built into the radiator. You can add a cooler if needed, or upgrade the radiator is you only need a slight redection in tranny temps.
With 200 degree water temp, tranny temp should be at 220-225, well within the safe range during the summer. Normal water temps are 180, tranny temps 200-210.
It doesn’t take long for the automatic transmission fluid (ATF) to heat up once the vehicle is in motion. Normal driving will raise fluid temperatures to 175 degrees F., which is the usual temperature range at which most fluids are designed to operate. If fluid temperatures can be held to 175 degrees F., ATF will last almost indefinitely -- say up to 100,000 miles. But if the fluid temperature goes much higher, the life of the fluid begins to plummet. The problem is even normal driving can push fluid temperatures well beyond safe limits. And once that happens, the trouble begins.
At elevated operating temperatures, ATF oxidizes, turns brown and takes on a smell like burnt toast. As heat destroys the fluid’s lubricating qualities and friction characteristics, varnish begins to form on internal parts (such as the valve body) which interferes with the operation of the transmission. If the temperature gets above 250 degrees F., rubber seals begin to harden, which leads to leaks and pressure losses. At higher temperatures the transmission begins to slip, which only aggravates overheating even more. Eventually the clutches burn out and the transmission calls it quits. The only way to repair the damage now is with an overhaul -- a job which can easily run upwards of $1500 on a late model front-wheel drive car or minivan.
As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees F. cuts the life of the fluid in half!
At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, which is commonly encountered in many transmissions, the fluid is only good for about 25,000 miles. At 240 degrees F., the fluid won’t go much over 10,000 miles. Add another 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and 1,000 to 1,500 miles is about all you’ll get before the transmission burns up.
If you think this is propaganda put forth by the suppliers of ATF to sell more fluid, think again. According to the Automatic Transmission Rebuilders Association, 90% of ALL transmission failures are caused by overheating. And most of these can be blamed on worn out fluid that should have been replaced.
On most vehicles, the automatic transmission fluid is cooled by a small heat exchanger inside the bottom or end tank of the radiator. Hot ATF from the transmission circulates through a short loop of pipe and is thus "cooled." Cooling is a relative term here, however, because the radiator itself may be running at anywhere from 180 to 220 degrees F.!
Notice I suggest 15k-20k fluid changes?
#7 ·
In general, get the biggest unit you can fit, afford, or get. Most trucks now come stock with tranny coolers, and its one of the first upgrades when you want your V8/auto to start making power. In some cases, its not a big deal though - I spent $150 and got a pro (9 months of 80hrs/week working only on trannies!) to rebuild my TH350, and that included the cost for a new torque converter AND the shift kit. Friendly hook ups FTW.
If you choose to keep the stock h2o cooler and add the air cooler, I'd probably put the air cooler on after it hits the radiator. The multi-pass units are best, since they can drop the temps down the most since your tranny fluid doesn't need much flow.
#8 ·
thanks everyone.. i picked up a universal one at pepboys today. it was a hayden #401. its a serpentine type cooler. it has the fins and passes thru a couple of times. im planning on mixing honda ATF with lucas oil transmission fluid stabilizer.
hopefully, it can be mounted in a way so that it doesn't create an obstacle when i get an FMIC.
