ok im doing a obd0-obd1 conversion on my 91 hatch and im wondering how i wire the obd0 vss to the ecu so that vtec will engage, i think ive asked this before, but i need a final answer on whats needed?
thanks, by the way the jkconversion harness i got was amazing, if anyone is in the market for an obd0-obd1 or obd2-obd1 harness go to http://jkobdconversionharness.com
i might be retarded, but i still dont get how i tap into that big huge wire, just shave off some insulation and wrap a wire around it and run it to b10?
yes, exactly... the VSS is a series of pulses connected to the chassis ground i believe. The ecu is just going to monitor the pulses just like your speedometer will.
ok thanks i finally figured it out last night, car ran awesome for like 2 hours then threw a code 16 again (injectors), i checked all connections and everything soldered, i have no idea whats giong on now, i think im better off just running each injector wire directly from the ecu to the inj.
Related Threads
Honda D Series Forum
posts
2.9M
members
66K
Since
2003
