i am thinking to get either a skunk2 rear lower tie bar or an ASR subframe brace. which one would you guys pick?
modsHXcivi 18,190 posts · Joined 2004 Add to quote #2 · Dec 25, 2007 Personally if rock the ASR ....:TU:
jredhonn Discussion starter 109 posts · Joined 2007 Add to quote #3 · Dec 25, 2007 is that because the subframe brace works better?
SilverCoupe 699 posts · Joined 2006 Add to quote #4 · Dec 25, 2007 it works in preventing the sway bar to rip out of that sub fram if your planning on running a 19mm or bigger sway bar
93 red ls 10,207 posts · Joined 2006 Add to quote #5 · Dec 25, 2007 ..I have a ebay lower tie bar cant beat it for the price... ASR is nice if you plan on gettign a sway bar in the future
jredhonn Discussion starter 109 posts · Joined 2007 Add to quote #6 · Dec 25, 2007 if i get the subframe brace kit (the one with sway bar), then i have to upgrade the front sway bar as well,right? oh, my car is 97 civic ex
jredhonn Discussion starter 109 posts · Joined 2007 Add to quote #8 · Dec 25, 2007 if i dont upgrade the front sway bar, wouldnt i have oversteer due to stiffer sway bar in the rear?
9 98`Civic`Si 29 posts · Joined 2006 Add to quote #10 · Dec 25, 2007 If you keep the sway bar stock like, such as one form a SIR you would not need or benefit from a sub frame brace?
H2Bcivic 8,206 posts · Joined 2005 Add to quote #11 · Dec 25, 2007 i dont see the purpose of a tie bar other then looks. only reason i have my asr is cuz i have a 22mm sway on my car
gpny 2,399 posts · Joined 2003 Add to quote #14 · Dec 27, 2007 I'm very happy with my ASR brace... I use ITR swaybars and hoosiers and have had no subframe issues.
jredhonn Discussion starter 109 posts · Joined 2007 Add to quote #17 · Jan 3, 2008 thank you for the inputs people. i think i will go w/ the asr kit!!
EJ1 SCRAPPIN 7,193 posts · Joined 2005 Add to quote #18 · Jan 3, 2008 black asr thats what im getting!
