I finally got around to putting in the crower st. 2 cam, springs, retainers, and adj. cam gear. but now the car runs like sh*$. i've checked all the vacuum lines and there are no leaks. the timing was off one tooth but now its fixed. the car will stall unless i put it in neutral at a stoplight (its an automatic). i then turned the idle up and i was ok, just idling high (1300 rpm) but now it will not stall but when i come to a complete stop the rpms go down to about 300 rpm and sometimes there is an odd noise. the valve lash is correct and i need to know what the problem is asap.
