Hi everyone, my first post here. I'm a late millenial with no forum experience so I'm sorry if I sound a bit dumb or whatever.
Anyway, I'm from Indonesia, trying to build my 1995 Civic Sedan to run on a P08 head with a P28 ECU, however I had some problems.
It's turning Code 19, 22, and 41 which means:
19 -> Bought wrong ECU. (I bought an Automatic ECU, not a Manual)
22 -> It wants a VTEC Oil Pressure Sensor (I have a JDM head, which doesn't come with one. ECU must've been USDM or something)
41 -> Heated O2 sensor...? (My car doesn't come with one, so that's a bit of a worry)
Now, an ECU guy I know said that he can chip my ECU to delete all those codes away. Now I know that Code 19 and 22 can be jerry-rigged... but that leaves code 41
If I were to delete code 41, that'd mean the car would run open loop, yea? Is that bad per se? If the tune is good that wouldn't be an issue but if the car gets a problem in any way shape or form that'd spell trouble.
Would it be better to jerry-rig an O2 sensor somewhere or just chip it...
SIDE NOTE: car isn't running atm. Turns out it needs a new block. lmao. so the engine is still in pieces at the moment
Thanks and have a good day, everyone
This car is my daily (well, was. but it has to be one again) so I can't afford it to break down again so I want the job to be as clean as possible. I don't mind spending a bit more money for a good job on this
