D15Z6
SOHC VTEC-E
Found in:
1995–2000 Honda Civic 1.5i LS (European Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm Ă— 84.5 mm (2.95 in Ă— 3.33 in)
Rod Length : 137 mm
Compression : 9.6:1
114 PS (84 kW) at 6,500 rpm
Torque : 99 lb·ft (134 Nm) at 5,400 rpm
VTEC Switchover : depending on load, max ~3,500 rpm in 5th gear
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on engine speed)
Fuel Control : OBD-2a PGM-FI MPFI
Ecu Code : P2Y
Head Code : P2J
Redline : 6,800 rpm
Fuel cutout : 7,200 rpm
D15B7
Found in:
1998-2000 Honda City SX8
1992–1995 Honda Civic GLi (Australian model)
1992–1995 Honda Civic DX/LX
1993–1995 Honda Civic Del Sol S
1992–1995 Honda Civic LSi Coupe (European Market)
Compression : 9.2:1
Power : 102 hp (76.1 kW, 103 PS) at 5,900 rpm
Torque : 98 lb·ft (13.5 kg/m, 133 Nm) at 5,000 rpm
Valvetrain : 16-valve SOHC (four valves per cylinder)
Redline: 6,500 rpm
Cam Gear: 38 tooth
Piston Code : PM3
Fuel Control : OBD-1 MPFI
ECU Code: P06
Head codes: PM 9-6, PM9-8
I don't know a lot about the D15Z6, I'd guess the mounts may be different, more akin to the D16Y7/8 that we see a lot of around here. I KNOW FOR A FACT that the obd level is different and therefore will NOT just drop in and drive away....and it took all of about 30 seconds of research to determine this, I pat myself on the back here.
Now, does the op have D16Z6? Hard to tell as he seems to have abandoned his thread, leaving us to twist in the wind....noobs, what can we do?
