Well I've got the drivers side wiring cut and pulled doing my tuck. So i remember seeing a thread somewhere about converting from 9006 headlights to 9005's.
So i start searching around and most sites say that you want to run 9005 high beam lights in your low beam position. And then If I do that will my 9006's be any brighter than my regular lights.
And if that's the case is there a good way to convert the hb's to foglights?
sorry... mabey to many questions and thinking out loud there!
I gotta admit that untill i read that I didn't even realize that there was a HB and a LB 9006, let alone different low beam bulbs with the same #'s.
If I do it, I'm going to swap to 9005 bulb connections since I have to solder the headlight connections back together anyways.
