Need help with wiring for sending unit 88 civic
55 views 4 replies 3 participants last post by  88civichatchh
#1 · (Edited)
Hey guys confused about wiring for the sending unit I tested the sending unit with volt meter and it’s working properly but when plugged in in my car doesent work I swapped the fuel pump and the connector is diffrent so im thinking that’s my problem
Do I have to repin the harness differently? Harness was not the same as original fuel pump harness but the way it’s plugged in the fuel pump is working properly just not the sending unit plz any help would be appreciated here’s some pics
I think I will have to swap the brown and green wire on the 4 pin harness and then run a ground somewhere for the brown wire after repining it but would like a second opinion before just doing it thx ❤ cars running great tho btw thx for everybody’s help i finished the mpfi swap 💪💪
