here are some tech articles and resources i used to find all my info and hopefully some of it will help you guys:
http://www.turbomagazine.com/tech/07...ath/index.html
http://www.aa1car.com/library/2004/eb20432.htm
http://www.bgsoflex.com/displacement.html
http://e30m3performance.com/tech_art...nic/sonic3.htm
http://www.team-integra.net/sections...?ArticleID=484
http://www.team-integra.net/sections...?ArticleID=471
http://www.wallaceracing.com/runnertorquecalc.php
http://www.metal-wear.com/
http://www.tprmag.com/issue/2/2_camshafts.shtml
http://www.superhonda.com/forum/f49/...t-tech-153746/
http://www.teammfactory.com/gearcalculator.php?refid=HT
http://www.homemadeturbo.com/forum/i...?topic=39723.0
http://www.honda-tech.com/zerothread?id=1983993&page=4
http://theoldone.com/components/
http://sms-products.com/index.html
http://jdmfabtech.com/
http://www.honda-performance.com/nproducts.asp
everything to why camshaft is better for you to intake manifold calculators to ITB info , some info on block thickness if you want to increase the displacement which would help the engine breath ,some little things to help increase horsepower NA, and some good companies for custom parts to set your ride apart if you so choose.
here is the list of parts and places to get parts most are without labor but some the job is basically a labor so ya here ya go.
Headwork
P&P with Larger valve bore etc -$700-1000
Depending on company and level of porting either Endyn or KMS
http://theoldone.com/components/cyli...g_and_Menu.htm
http://www.honda-performance.com/services-porting.asp
conversion to vtec head and possible new engine-$300-600
complete head swap with new ecu buy off a wreck or new engine from wreck
Camshafts Depending on Vtec vs Non
Vtec Head D17A2:
Stage 2 or 3 camshaft-$380 Crower
http://www.dezod.com/cat_camshafts.cfm
Non-Vtec Head D17A1:
Custom ground camshafts: $325-480 dollars Crower or Colt Cams , both have been emailed and will make a custom grind for our car
To B. Campbell,
Thank-you, for contacting us.
Sorry we have not seen this model as of yet.
However, I have been working with cams for over 25 years and designing
something new has always been my one of my passions.
A few questions need to be answered first on the valve train, example: solid
or Hyd lifters, roller or flat tappet, sohc or dohc etc.
We would need to see your cam first to determine what the stock lift and
duration is. At this point I can design something with you over telephone
that will suit what you're after as well as cost.
There is no charge if we can't do anything for you. We will also pay for
the return shipping back to you if this is the case.
If you are interested please give us a call at your convenience and I will
go over the details.
Thank-you,
Geoff Bardal
FOR OUR U.S. CUSTOMERS REGARDING SHIPPING
When sending in your cams, via any courier service or the post office.
Please put as the value of the cams to be under $10.00.
This falls under NAFTA and no duty charges will be inflicted on you.
Please put on the way bill as well as on the package.
"Damaged Camshaft for Repair and Return"
PAYMENT
We only accept International Money Orders in US funds made out to Colt Cams
Inc.
COLT CAMS INC.
#54 - 3347 262 nd Street
Langley, BC
V4W 3V9
TEL: (604) 856-3571
FAX: (604) 856-3572
www.coltcams.com
geoff1@coltcams.com
www.coltcams.com
Brent,
If it is going to be a custom grind you are going to have to send in the specs along with your cam. The price for that would be $100 and the motor that you have is a non vtec, the D17A2 is a vtec motor. the cams are different. We dont make cams for single cam non vtec honda motors. but if you can get the specs that you want for your cam, we can do it.
Thank You,
Marco Romero
Crower Cams & Equipment Co.
Phone (619) 690-7806
Fax (619) 661-6466
http://www.crower.com/cat/import/honda/cams/d17a2.shtml
Also Bisimoto will also do a custom regrind to whatever stage you want for $225 with a provided stock cam
Spring and retainer-$300-350 Crower or Supertech
Valves +.5 mm overbore set-$265 KMS performance
http://www.honda-performance.com/info-lv2.asp?id=312
so that brings to headwork with a vtec head to: $1995
headwork without vtec to : $2095
headwork and conversion to vtec : $2595
all without labor and shipping costs on some
Bottom End
Sleeves-$250 Darton $750(installed by Darton)
http://www.darton-international.com/sl_import.htm
The only sleeves we have for the D17 blocks are the 300 Series open deck sleeves. The sleeves come for stock bore size and have a max bore of 77mm. You can go with a 78mm bore on the D16 block but the D17 is casted differently than the D16 so they would not use the same sleeves. The D17 300-011 sleeves take about a week to make and cost $250.00 for the set. Installation is an additional $500.00 and takes about 15- 20 days.
Let me know if you have any more questions.
Thanx,
John
John Catapang
National Sales Manager
Darton International, Inc.
2380 Camino Vida Roble Bldg. K
Carlsbad, CA. 92011
sales@DARTON-international.com
tel:
tel2:
fax:
800-713-2786
760-603-9895
760-603-9629
Pistons: $500-520 stock bore vs custom bore Wiseco
http://www.wiseco.com/Catalogs/Automobile.aspx
Brentt,
We can custom make the part for that bore and whatever compression you would like. Cost is approximately $139.36 each (includes rings,pins,clips and coated skirts) and it takes 4-5 weeks.
Best Regards,
Wiseco Piston Co. Inc.
Crankshaft lightening- $465 – KMS
http://www.honda-performance.com/ser...ning.asp#crank
Connecting Rods- $785 – Crower Maxilite
http://www.dezod.com/pd_crower_maxilite.cfm
there is a rumor of carrillo making a cheaper version for rods.
Shot peened and balanced connection rods- $135 if you don’t want aftermarket and just a little more insurance
Fuel Managment
Standalone ECUs- $1000-2000 Hondata K-Pro or AEM EMS
Hondata depends on price of donor ecu
http://www.dezod.com/cat_engine_management.cfm
http://www.hondata.com/prices.html
Return line Kit with fuel pump upgrade:$650 Street Level Performance
http://www.streetlevelperformance.co...ion Kit.aspx ( this could also be pieced together for a little cheaper)
Larger Injecters-$100(used)- 546(new) RSX injectors
http://www.dezod.com/cat_honda_oem_parts.cfm
Intake manifolds or ITBs
ITB- $500- 3000 Danstoy, Hayward Performance Intake Systems, ExtrudaBody, DIY
http://extrudabody.com/Products/ITBs.html
http://www.haywardperformance.com/intake.htm#custom
Our custom ITB setup will run for 1,200.00. That is hardware only. We can either use Toyota 20 valve ITB's 40mm, 44mm or brand new TWM ITB's which are a little more pricier. You would also need to run a Full stand alone management.
Feel free to ask us any more questions if you have them
Jed
Manager of Danstoy
http://www.danstoy.net/products.html
Custom NA intake manifold- $1050-1250 Endyn
We haven't built one for the D17's. We have built a few D16 manifolds, however.
I'd have to see one of the stockers to tell you if we could do it.
Be prepared though....the fabbed manifolds run in the $1050-1250.00 range.
*all prices where what they quoted me a while ago so they dont represent what you could pay*
and for the record i did the research for all this i also go by civic-driver on civicforums so dont think i stole this from someone else. hope this helps
