civicefdx said:
ok, big question. Which to swap in place of my usdm d15. they both make the same stock power. obvious difference is the cams, so which would be better to put in my 91 dx hatch? ive seen zc swaps go for like 600-700, while the jdm d15 is significantly cheaper (400-500) will i pay for what i get? should i spend the extra just for dohc, or less for vtec? HELP
91 dx HATCH
if you go D15B my prices around the Southern Cali area go anywhere from $300-$400
The DOHC ZC is over-priced by many known companies but I swear you could pick one up for around $400
The slight price difference between the engines doesn't count for the OBD-1 conversion ahead of you
sure you can stay OBD-0 and rig some type of RPM switch but you're gonna be far from the engines full potential
The weight difference is NOT 80 lbs, more like 40lbs at the most
I like the added "umph" the DOHC ZC has over the D15B
FOR your car, I suggest the DOHC ZC for it's simplicity
For EG's and OBD-1 people, I say D15B
