d16y vtec swap help?!?!?!
1 reading
1.6K views 9 replies 6 participants last post by  devilman
G
#1 ·
:confused: :confused: hey wats up people im new to this d-series....i got a d16y on my 98 civic hb........i want to swap the head to a vtec one i wanted to know wat do i need for ever thing to work out good..........:confused: :confused:
#3 ·
Search....do some heavy research.
I'll give ya a tid bit of help....hint hint.... that might make you smile.
If you are correct in saying you have a d16y as in d16y8.....mmmmmm......that is vtec. I assume you need nothing!
#4 ·
there is an engine call the d16y7 non vtec. btw i never knew that hatchbacks come with vtec.
#7 ·
CX, DX, VX and SI from what I know. Im not sure if the later years have all those same models but I know the 92-95 do. Im not sure whether or not your car has the Y7 or Y8. But research, reasearch and when you think you're done, research some more. And then, you will be ready.
#8 ·
HX is not a hatchback that was the d16y5 vtec-e coupe that year hatch was cx dx thats it..non-vtec motors in both
#9 ·
Everybody's right here it sounds and all points seem valid.
The missing piece of info is what type of d16y the poster is talking about matching a vtec head to.
y8=vtec
y7=non vtec
all the rest.....help me out people.
As far as actually swaping heads & what is needed I don't know.
Maybe some nice people here will help but keep searcing for your own good man. Research helps ALOT!!!
