1 - 13 of 13 Posts
Hello, I will probably buy a zcspeed adapter plate for my OBD0 ZC. What intake manifold will fit to my engine with this adapter plate ? What are your advices ? what is the best power gain by price ratio ?
Thank you
93 Legend L Coupe.
Best OEM, possibly, but if one wants to mount a SOHC supercharger or get more power with the same amount of boost and switch to, say, an Edelbrock manifold, it is entirely worth it, and that is exactly why I have my ZCSpeed adapter plate.
1996 Civic Type DX
The DOHC ZC IM is far from the best IM. I don't particualarly care for any OEM IM.
The ZCSpeed plate worked great on a customers A1 using a Performer-X. It only needed to be modified to clear the block as the head was milled.
1991 Honda CRX
The obd1 dohc zc im is more like a z6.
Not even close, put them side by side. The DOHC ZC head has 2mm larger ports, and the intake manifold is larger as a result. The plenum is way larger, and I'm fairly sure the runners are slightly shorter.
just run the obd-1 dohc zc IM with a nice TB and you will have plenty of flow in upwards of 400whp
I like this one
i bought the obd1 dohc zc intake manifold, and it works great on my turbo 89 integra
d16a1 .. plus it now allows me to use newer and larger honda/acura throttle bodies, as well as remove my MAP sensor from the firewall. i ended up bolting a b18 throttle body up to it
They call me Awesome!
7 months old man...
1 - 13 of 13 Posts
