1 - 12 of 12 Posts
Can I use the zc tranny in an 93 eg housing(dx) with an hydro clutch?
what year ZC tranny?
cable, 4th gear will need grinding
hydro, all gears drop right in, but likely the ratios are the same. Being your in Germany though, I could be wrong on the gearing.
I mean the german ed9 crx tranny. Its 5 an 5 gear cable tranny. I believe it has the same gearratious as the zc
use the 3-4 ZC gearsets, 4th will need to be ground for clearance, and then a normal CRX DX 5th gear set, .771 ratio.
This will put your top speed at about 140 mph if you happen to cruise your nice Autobahn.
yeah I use the zc 3rd and 4th gear, but with the 5th Im not shure. Maybe I use the stock for cruising. I must datalog if the car drive with the new block more than 140mph. Im hoping for more topspeed than an eg6 :)
I mean the 90-91 ed9 tranny, on agerman info I get this info:
1. 3.250
2. 2.052
3. 1.416
4. 1.103
5. 0.870
but I dont think thats right, this would be the shortest d tranny ever
no I have found the error, this was the specs from the ee8 (b16a1 engine).
Here are the corrects:
3.250
1.944
1.346
1.033
0.878
3.250
1.944
1.346
1.033
0.878
Yeah. those ones are correct. In your other post, 1st was right but 2nd - 5th was from the Y1 trans from the SiR I. But still, having a ZC 1st - 4th with an HF 5th and a 4.5 FD would be SIIIICK.....if that's possible.....
:hammer:
1 - 12 of 12 Posts
