1 - 4 of 4 Posts
The engine starts just fine but when I get on the throttle it will climb but its like 2step all the way up. I have a chipped p06 with a p29 map. Before the map if poured gas out the exhaust. I played with the timing and no difference. I'm thinking its a bad dizzy but want conformation before I spend money. Any help is welcomed.
I forgot to add that when the engine was cold it ran great with only a slight sputter under preload of the trans. I'm auto btw.
08 H-D Ultra Classic
If gas poured out of your exhaust it sounds like your injectors are in your exhaust manifold and not your intake?
1 - 4 of 4 Posts
