my buddy says that the wiring is right on with the diagram,and that we think it might be the ecu,He said he has used them before in 1.6 and 1.5 but could never get them to work on the dohc zc.It has me puzzled b/c that is wat every forum on here calls to use for a dohc ac swap is the pm7 or the pg7 ,but i still believe it to be the wiring somewhere that is wrong.What should i do about this situation?
first off, quit listening to your buddy - next, in order for us to help you out, you need to answer the questions asked by T-rilla, namely:
1. What ECU do you have?
2. Do you have a Check Engine Light showing on the cluster? - if so, what codes?
3. What distributor is on it?
4. Are the wires in the distributor connector in the right locations?
in addition, i would also ask:
1. are you using the Si engine harness that was in your car?
2. when you turn the ignition "on", does the check engine light come on for 2 seconds and then go off?
3. do you have the spark plug wires in the correct location on the distributor?
