1 - 6 of 6 Posts
X
ok heres the problem only way the car will start is if i hold down the gas and it only runs for a second or two and dies its getting fuel spark and the ecu isnt throwing any codes so anyone help!!!11111 :shocked:
sounds like my old car when the distributor went out, no codes or nothing, try finding someone in ur area with zc trade dizzys and see if it works
what have u done to try to fix it?u should always change cap and rotor.try changing wires too.is it in time?are u throwing in codes?are the injectors still good?is the fuel filter cloged.ie thats some thing u should also change when doing a swap.hows the fpr?
Donkey
its your dizy. might be just the cap or rotor. Replace them and see if that solves the problem. I just had the same issue with my D16a8 and im just waiting for my parts to arrive. then ill be ruinning again.
Yeah sounds like the dizzy. I had the same thing, a hair line crack in the pick up somewhere.
You will have to get a whole new one, cant just replace the cap
1 - 6 of 6 Posts
