So for a timing belt, water pump, header, intake, etc... I need parts from this motor?everything from the top of the block up is the same as 88-89 Integra D16A1
yeah, it is that easy - don't worry about the parts store - as long as you know what parts you need, you are set - you said the car is a DX, right? - the DX used the D15B2 engine which had Dual Point Fuel Injection - the DOHC ZC (or Si for that matter) uses Multi Point Fuel Injection - in order to run the MPFI engine in the DPFI car, you will need to do some wiring changes to convert it - not a big deal, but takes 2-3 hours to do it right - you can get instructions for converting it here:Wow, thanks. I jsut printed that so I have it. If it's THAT easy, I may jsut go ahead with the project.
