In your opinion what's a better engine? What has better aftermarket support? And how about whether or not to go Turbo or N/A. I'm looking to put either in my 90 Civic Hatch (4th gen). And if anyone knows what is the engine name for the SOHC non-vtec. I believe they are stock in 4th gen Si civics. I believe that there called the D16A6. Correct me if I'm wrong. Thank you for your opinions and your support!:dots:
the a6 (your right when you called it that) is gonna have more support by far. But the ZC is not a bad motor at ALL. Actually its a very nice little motor.
it really depends... are we talking about the DOHC ZC? SOHC non-vtec ZC(similar to A6)? or the sohc vtec ZC(similar to Z6)? the sohc non vtec ZC is the same as an A6 with a tiny bit more aggressive cam. the SOHC ZC has the same aftermarket support as the A6, and the vtec ZC as the Z6.
the DOHC ZC is a D but a different breed(bolts in just uses a hybrid of parts). all good platforms for a build. i would read up on the benefits and draw backs of each and compared to price to choose the best for you.
Discussion Starter · #4 ·
I'm talking about the SOHC non - vtec engine out of 4th gen si civics. And yes were talking about the DOHC ZC. Sorry for the improper clarification
I'm talking about the SOHC non - vtec engine out of 4th gen si civics. the D16A6, or A6 for short.
your fine just wanted to be clear with what ZC. if I could I would've gone with a SOHC engine. (probably the A6, or Z6) and built it. the DOHC ZC is a great engine and I love it. it pulls and its a great engine (for me compared to my b2) i would recommend it for a stock upgrade. however if i was going to build a motor I would go with a SOHC because there easy to find cheap, and cheap and simple to build. the dohc zc has a cluster of different parts and a funky compression ration to work out with sohc turbo pistons(can be done) just not as easy to do as a sohc IMO. just my 2 cents.
I love my dohc ZC. but will be removing it once my Z6 is built.
ej2
yeah..get the a6 or the sohc nonvtec zc. (Thats what i have)
get a si tranny and bolt ons, you'll like the pull!
Do ya thing.
Im Bringing TSEXY Back!
^^Look up
How so?
They have both the sane amount of support considering there the exact same engine except the ZC(non vtec sohc)has a better cam profile to work with.
n00bs.
