G
·I have a set of Web camshafts(Grind 148E) that I had in my previous 88 Integra. The cams worked very decent and the Idle was like stock. Since then I replaced my engine with a suppose factory replacement japanese engine(87 Brown Top). The reason I say" suppose" is because I can't find the freaking stamp on the block yet, but I will have time this saturday thanks to the help and info from other group members. Anyhow I was told that these Web cams may not work properly on my current engine if indeed my engine is a JDM-ZC beacuse the intake cam needs a slighty more aggressive grind. I checked the Web Cam web site and they do list 86-00 Integra cams as well as 86-89 Integra ZC cams.
Has anyone with 86-89 Integra ever installed performance cams for a D16A1 engine in to an 86-89 ZC-JDM motor? and did it work properly?
On a side note, Does anyone know the duration on the intake & exhuast stock D16A1(USDM) cams as well as the ZC-JDM(86-87 Integra) cams?
I will try to cut & paste the cam spec info from the webcam web-site.
Any help would be greatly appreciated. These set of web cams have been sitting under my bed boxed away for almost 4 years and I want to have them install once again.
Thanks, Ed.
Thanks, Ed.
