1 - 10 of 10 Posts
I was wondering what the benifit would be swapping my the stock SOHC head for a ZC head. I know i have to wire it for 4 inject which isnt a problem and use the ZC ecu which isnt a problem, the only reason im considering this is that my friend was talking about it and has all the parts and really all that i have to do is swap the head out.
Any input on this would help as in opinions and people that have done this before i remember a few years back some people i know did this to there car thanks
Honda
DOHC ZC head...will i have a problem with the water holes lining up???
coolant passages..........its an open deck setup.
so in other words i wont have any problems other than wiring it up, anyone knoe the compression i would get it i did the DOHC ZC head with the stock D15B7 pistons?
The H Badge is it!
91 crx
the DOHC head will not fit on the sohc block.
the b7 pistons will stick out of the block if you put them in any sohc or dohc zc. /thread
1 - 10 of 10 Posts
