1 - 11 of 11 Posts
honda
sorry having a blackout during posting this thread, this is engine B Brown Top Zc. Everything goes in except for one socket I will post that picture later.
honda
I bought this a month ago comes with this engine
Then the engine broke down due to overheating + stupidity
Then found this Rover Engine but one of the bolt from jdm zc wont match so change it
To this one Brown Top Zc
honda
After I have done a research about black and brown top engines they both run with the same ecu but the only different is the distributor?
D16A1
Found in:
1986–89 Acura Integra (USA)
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Valvetrain: DOHC 16-valve (four valves per cylinder)
Fuel Control :pGMFI
CG Gearbox – Cable Transmission
1986–1987: USDM Browntop
Compression: 9.3:1
Power: 113 hp (84 kW; 115 PS) at 6,250 rpm
Torque: 13.7 kg·m (134 N·m; 99 lb·ft) at 5,500 rpm
Piston Code: PG6B
ECU Code: PG7, Vacuum Advance Distributor
1988–1989: USDM Blacktop
Compression: 9.5: 1
Power: 118 hp (88 kW; 120 PS) at 6,500 rpm
Torque: 14.2 kg·m (139 N·m; 103 lb·ft) at 5,500 rpm
Piston Code: P29
ECU Code: PG7, Electronic Advance Distributor
1 - 11 of 11 Posts
