1 - 4 of 4 Posts
Ok so I have a zc dohc and a 2.0 prelude belt when I install the belt to the manuals way to install it it is loose (Likly the spring on the tensioner is weak) anyways so I have to apply pressure on the tensioner it's self my question is how tight should it be right now it seems pretty tight like even in between the cam gears at the Top I can almost play a tune on the belt... Thanks
94 Civic Cx
I usually had about a quarter inch on one side and half on the other when i did b series not sure if zc is the same although i know you can run the b16 belt on the dohc zcs
1 - 4 of 4 Posts
