1 - 9 of 9 Posts
Does anyone know if I can take the the diff out of my zc tranny and put it in my dx tranny? I want to eliminate torque steer and have a strong diff(ZC), as well as longer gearing(DX).
Any help would be appreciated.
Thanks
ZC has DX FD ratio @ 3.889, wanna try again?
ZC and DX have the same non-LSD diff with the weak diff pin.
Beyond that info lets discuss the 35mm vs 40mm bearing issue :)
so it cant be done... I mainly wanted to get rid of torque steer, and have stronger axles. Ill be running about 250 whp.
I have a ZC diff with the replacement "golden" diff pin and axle seals if you want, it would have to go in a Si case, but you could swap whatever FD you wanted.
But really a OBX would be the best option.....
B
bone what year does the "golden" diff pin come in so I can swap it into my Si.
it was a replacement pin, didn't come in anything OEM production
Why would you wanna put a ZC diff in a 6g case? no axles made to make it work
1 - 9 of 9 Posts
