1 - 7 of 7 Posts
88, 90 crxs
I'm trying to figure out what oil pump works on the 3 stage motor because I'd like to replace it, also wondering what else I could/might want to change while the motor is out. Maybe the rear oil seal? Any suggestions, thanks.
Honda Civic
WHAT!!!
GO to Majestichonda AND try the search button at the top.
:uh::uh::uh: theres tons of posts on oil pump, were to get it. whats this 3 stage motor ? stage 3 vtec solenoid?
88 ED6
D15Z7=JDM D15B 3-stage VTEC....it wouldn't show up on MajesticHonda.
Use any 96-00 Oil pump(P7A I believe).
There's seal kits but yeah, rear main seal, oil pan gasket, timing belt tensioner, timing belt, and water pump are a good idea to change since you have everything apart.
88, 90 crxs
That is interesting... because autodynamics-honda.com says that " This oil pump does NOT fit the D15Z7 and JDM D15B 3-stage SOHC VTEC." when referring to the P7A oil pump. I wrote them an email but have received no reply.
88, 90 crxs
yeah, Seng @ Autodynamics-honda.com got back to me today and informed me of the unique oil pump being P2J. Good to know the full p/n. I asked him to see if he could get me one.
1 - 7 of 7 Posts
