Scammer
Engine y8 bottom and z6 top
The reason I'm running y8 bottom I will be using y8 oil pump and pan.
(currently have two dip sticks looks dumb) z6 & y8
I will not boosting right away just building a block.
So far this what i have,
Arp head studs
vitara pistons
eagle rods w/ arp bolts
walbro 255
King bearing kits
330 cc injectors
___________________________
Only aiming for 250-300 hp
Questions?
1)what kind of intake should i use?
2)what kind of fuel rail?
3)do i need a cosmetic headgasket? if not what should i use?
4) Block guard needed?
5) what kinda of number should expect with a good tune?
6) what would be a good cam?
IF I NEED SOMETHING ELSE OR WOULD BE A GOOD IDEA PLEASE LET ME KNOW!
DOOKIE
your def gona need to get some bigger injectors 330s are to small man, a stock fuel rail will work. i would go with and oem headgasket, no block guard total waste of time, looks into delta cams
'99 Honda Civic Ex
I made 300whp with a custom JGE engine dynamics intake manifold(Z6), 750cc injectors, stock fuel rail, stock headgasket(Y8 ), JGE engine dynamics regrind cam(85VT35, I think)(Z6), block guard.
Y8 Block
Z6 Head(JGE engine dynamics Pro series head)
T3/T4 turbo on 17psi
Forget the blockguard, waste of money, as well as the cosmetic headgasket(had 2 fail on me). I'm learning from my first built and doing it right this time.
