1 - 4 of 4 Posts
I'm planning on buying an STR cam gear off of someone who claims that the gear is for either a Y8 or Z6. He says him and a friend used it on both engines and it worked fine. i thought they were a tooth off or something. Can anyone comfirm if it will work or not? Thanks, Vince.
kommon_sense said:
Yes, they are different. If you look at some companies, they actually offer different gears for 92-95 and 96-00. You *can* interchange them, but you may have to fiddle with the timing.
Every company i look into has only one for all SOHC's. If they are different how will that affect my adjustments?
Vince
1 - 4 of 4 Posts
