1 - 2 of 2 Posts
hi all!
my setup is z6 turbo 10 psi cooler run with p28 and 390 dsm injector
i make my first programme with uberdata 1.72
start with p28 map
add boost map
i test my programme and run good.
the probleme is when i change the value of my injector to 390cc
my car wont start
i check my fuel map and my first value is now 2.46 before is 4
it is better i us crome?
Before you change the injector size in uber what afrs are you running cruise, idle, wot? It may be cutting to much fuel.
If you want to use uber use uber if your want to use crome use crome.
1 - 2 of 2 Posts
