1 - 6 of 6 Posts
B
I just swapped another z6 into my 93 si. I started it up and there's white smoke pouring out and when i try and rev it up even a little bit it bogs and almost stalls. Does anybody know what could be causing this?
Del sol
bogging -->u hooked up the map sensor line goofy or prob. there in that area
the white smoke, eh a coolant leak some where cuz its burnig on something hot--->check all the coolant lines/ seals ect
my .02
B
the fuckin e-tard that hooked up the harness mixed up the 2 sensors, AND I EVEN HAD THEM FUCKIN MARKED, solved both problems thanks a lot
DROP IT LIKE IT'S HOT
2003 Civic Si
Glad to hear you fixed your problem.
B
thanks for the responses, fuckin bolt on the steering knuckle is fucked from my buddy hitting it with a hammer trying to get it out so i'll have to run a die around it or something tomorrow. wish i could have got it rolling tonight but oh well
1 - 6 of 6 Posts
