1 - 6 of 6 Posts
My Honda
Hi i have a question. i bought a 95 civic with a d16z6 motor in it and i was driving home and it threw the rod through the block. i was wondering if i could use a d16a6 block out of a 1991 civic hatchback si and swap the blocks?
'97 Del Sol
use your stuff from your z6 also
^^^What does that mean? If he swaps a A6 short block he really won't need anything from the Z6 bottom end.... I'm not sure I would want to use any of it after throwing a rod anyways unless I had a shop inspect and clean first.
@OP I'd check the head out too before the big day, it is prolly fine but I'd want to play it safe and check it real good just incase
Good Luck:TU:
My Honda
Thanks for all the help and support. In the process of sepperation the block frome the trans i cracked the block where it meets the trans. is this ok or can it be fixed? the one with the hole in the block is what i did to my z6 block
1 - 6 of 6 Posts
