Hi guys, I have read and search all over D-series for this problem but couldn't find it. MY car was running one day and the next day it won't start. It crank but won't start. I have check fuel ( smell fuel, and spark plug is a little wet when take off), sparks ( took off spark plug and use a flat head to test spark plugs wires), leaks ( all line are plug right), and etc. I also did a compression test it came up 160,120,120,120. but can't figure out what's wrong. But there's one things tho. If you cover the TB with your hand it will Start, but If i remove my hands from the TB, it will slowly die. SO Plz can someone help me with this. Thanks a lot.
civic
160,120,120,120 i've never done a compression test nor have no idea what the numbers mean, but 160 120 is a difference. is it smoking at all?
No, No smoke at all. Is it because of my comperssion. Maybe bad piston rings? Bent valves, burnt valves?
