1 - 3 of 3 Posts
The Z6 manifold and Tbody uses a built in Fast Idle valve, with no wires or sensors going to it. However the A6 manifold/tbody uses an external FITV with a sensor.
QUESTION
Can i use the Z6 manifold/tbody combo and leave the wire hanging? will it idle right?
It will run fine. The only things that need to stay pluged in on the manifold are the IACV and air temp. sensor.
Thanks, but is that what my CEL is from?
1 - 3 of 3 Posts
