1 - 12 of 12 Posts
i have a d16y7 so i bought a z6 intake manifold and bolted is on..went through some bull because nothing is ever perfect...but when i started the car it sounded horrible like a vacuum leak and it idled at 2500. I checked the hoses and everything seems right. I was told it was because of the y7 throttle body and the check engine light is on
dont use the y7 throttle, it doesnt seal up no matter the gasket
find yourself a d15b7 or d16z6 throttle for best results
yeah I'd just throw a z6 throttle body on too. why not? I think it's slightly bigger than the y7 throttle body anyway. I was hoping to see a write up here too...may need to be moved forums.
the y8 has shorter runners, but the plenum is bigger, and needs to be filled up more then the z6.
the y8 is more for topend on an otherwise stock setup. great for boosted setups though :bigok:
1 - 12 of 12 Posts
