1 - 10 of 10 Posts
ok im trying 2 build a high comp z6 motor. any thoughts? the head is fully built. wut should i do with the bottom end?
get it balanced. get new bearings. check the clearances, make sure they are all in spec.
if using stock rods get them shot peened.
get all new seals of course. cleanup everything on the bottom end.
somebody else will anything i missed
P29 pistons will net you about an 11.8 compression with the z6 my y8 was at 12.6 with a 2mm HG
wut car did the p29's come in? will i have 2 do a mods 2 the block 2 fit them? and wut hg should i get?
p29 and pm7 pistons are the same the pm7 came in dohc zc and the p29's came in the 1st gen integra with the d16a1. they fit right in there and i would just use the stock z6/y8 headgasket.
1 - 10 of 10 Posts
