1 - 3 of 3 Posts
I have a bad Y8 motor.. very loud knocking. i am assuming it's got a spun rod or crank and i have a spare Z6 that i could use for parts. Will the Z6 crank work in the Y8?
u have to use all z6 n crank n pistons so it works
You don't have to use the rods or pistons. Hell the rods are the same and people swap pistons all the time.
You would have to use the Z6 oil pump and then you won't have a dipstick to check your oil.
1 - 3 of 3 Posts
