1 - 10 of 10 Posts
2000 civic 2 door ex
what is the difference in the z6 and y8 head studs??
how many bolts are different lengths?
bump need help soon
so if i used the z6 ones then i could use washers?? or is that way to ghetto??
how many bolts r different
OMG TOTALLY COOL TITLE!!!!
88 y49 crx
dont use washers. what are you doing that you need the diff? all the y8 ones that i used on my motor were all shorter than the z6 ones i have.
i have a z6 block and a y8 block but only a y8 head
im building one motor while im driving the other motor
88 y49 crx
if you are putting the y8 head on the z6 block you will need one y8 headstud. but if your using the y8 block and y8 head then use all y8 headstuds
ok thats what i thought!!!!!!!!!!!!1 THANKSSSSSSSSSSS
1 - 10 of 10 Posts
