1 - 10 of 10 Posts
2000 Honda Civic Dx
Selling all my left over stuff. Prices do not include shipping.
^a6 oil pan $15, d17 VC $30
^a6 crank timing gear with washers $10
^misc. z6 head parts (springs, keepers, retainers, valve seats, some valves) $15, vtec solenoids $20, oem honda resistor box $10, obd1 injector clips $10, obd2 distributor plug $5, obd1 distributor plug $10, sensors $5
^a6 cam (some rust on it) $40, z6 cam (this is bent) $25, z6 valvetrain assembly (it's all there just in pieces) $40, 96-00 DX gauge cluister (completely working, 140,000 on odo?) $20
^z6 black box $5, z6 main seal $10, a6 IM bare $20, z6 IM bare (bent fuel rail studs) $30, never dizzy cap (unknown, scratches) $5, 56mm TB $10, pm3b cam gear $5; Z6 oil pickup sold
^misc. a6 and z6 stock conrods and pistons $10
^DIY oil catch can $25, obd2b to obd1 harness (good quality) $30, 56mm TB $10, IACV $5, used plug wires vtec $5, z6 brackets? $10
2000 Honda Civic Dx
^a6 or b7 head not sure this is heavy and rather would not ship $30
^z6 water necks $10, z6 timing covers $10 each, z6 ac brackets $25, z6 main seal $10, z6 water neck $5, z6 timing gear $10,
^a6 water necks $10, a6 oil pickup $5, a6 crank pulleys $30, a6 black box $5, a6 timing covers $10 each, a6 ac brackets $20,
^a6 water neck $5, a6 main seal $10,
^z6 valve cover pretty clean SOLD, DC2 OEM sway bars and strut local only! $40
Meat Popsicle
91 CRX Si
Is the A6 pan dent free? Drain plug threads good?
If so, I'll take it. LMK how much shipping would be to 78254
Do you happen to have the A6 clutch cable bracket that bolts to the cylinder head cover?
1 - 10 of 10 Posts
