1 - 20 of 41 Posts
Civic ?
Two main questions..... Any throttle cable bracket idea's ? I only have one bolt on my intake at the moment.
Also the throttle body has slight bend in it. What intercooler piping fits best ? and has to go through the fender well on my setup as i am using both torque mounts.
95 ex coupe
you will need to custom do you IC piping to fit correctly.
with those you should be able to use your stock throttle cable bracket if i remember right.
Civic ?
Please do. And I did just watch a video where someone used a 30 or 45 degree silicone elbow to intercooler piping that went straight from the elbow to the bend that went into the fenderwell..... Comments on this ?
95 ex coupe
as far as the IC piping a angled coupler will work. but when it comes to the piping you want as less couplers as possible. less chances for leaks!
Civic ?
That would be why.... I purchased mine off H-T in the classifieds. Guess I have to make something up. Thanks for the picture that will help a TON.
91 CRX Si
Mine didn't
91 CRX Si
Still in the building phase. However, it looks like my stock bracket might just fit.
Civic ?
Okay. I couldn't get my OEM to work comfortably but did manage to make it work rigging it up with one bolt holding it in and some grinding.
91 CRX Si
Which chassis are you?
How do you guys like the edlebrock intakes? from my research i keep reading that they are a waste of money. Im new to D series always been a b series or h series guy... but im currently boosting a mildly built d16y8 with an hy35... personally i think the intake would have to be better than the stock one. but i read differently. Thanks... sorry to thread jack you
1 - 20 of 41 Posts
