1 - 15 of 15 Posts
I picked up a complete d17a2 today, FREEBIE. VTEC head and all. Going to use it to make stroke a d16a6.... to bad the head wont fit... :fag:
....hey free is free!!!
who cares!!
hey guys just had a question regarding the d17. Would the cam be interchangable with my friends d16y8?
yeah thats what i thought. doesnt really matter. I doubt it would be any better than the stock y8 one anyway
Im selling the head, or maybe trade for parts... but im keeping the rotating assembly...
B
so the pistons for a d16 will fit in a d17? I have a d17a2 and want to build it, but its hard finding pistons and rods. Can I use pistons and rods made for a d16? I have seen lots of those around.
you can use the pistons, but the rods are slightly different. same length, but ive heard the crank journals on a d17 are larger diameter, so d16 rods would need to be machined... but you can use d16 pistons with d17 rods and crank
B
cool. that makes finding some low comp. pistons for my turbo build easier. So just making sure. I can buy some low comp pistons for a d16, some good rods for d17 and they'll work? the pistons are the same diameter? That's awesome. Thanks man
If you are talking about using these parts in a d17, then yes, d16 pistons and d17 rods will work. Just FYI, the compression you yeild will be different from what is advertised if you go with d16 pistons.
1 - 15 of 15 Posts
