1 - 6 of 6 Posts
Anyone have a link to the specs on each cam. I searched but did not find them.
I read the sticky on cams and gears but wanted to know actual lift and duration specs on each.
Let's Go Oakland!
http://www.honda-tech.com/zerothread?id=385741
D16A6 Cams
........................Adv [email protected]
........................ Int/Exh...Int/Exh...Lobe Separation...Gross Lift
Stock D16A6.......222/224..194/196........110................333/362
Crane#251-0010.226/228..200/202........107................384/376
Crane#251-0012.232/234..206/208........108................394/386
Crane#251-0014.232/228..206/202........110................394/376
Crane#251-0016.242/244..216/218........110............... 425/416
D16Z6 Cams
Comp Cams and Zex #59100
Adv Duration [email protected]
___Int/Exh__Int/Exh_Lobe Sep_Gross Lift
PRI..228........186........111..........285
SEC.232........190........115..........300
VT..256.........215........103..........440
EXH.252........210........111..........400
Comp Cams and Zex #59300
PRI..232........190........111..........300
SEC.236........194........115..........310
VT...260........220........107..........455
EXH.268........216........111..........430
D16Y8 Cams
Stock D16Y8 Cam
PRI..211........183........115..........300
SEC.215........187........113..........319
VT...247........217........114..........397
EXH.235........204........110..........370
Crane#252-0010
Adv Duration Duration @ .050
____Int/Exh__Int/Exh__Lobe Sep___Gross Lift
PR.....214.........186.........108.............319
SEC...218.........190.........106.............327
VT.....258.........224.........106.............423
EXH...238.........210.........114.............386
Crane#252-0012
____Int/Exh__Int/Exh____Lobe Sep__Gross Lift
PRI...214.........186..............112...........319
SEC..218.........190..............110...........327
VT....266.........232..............110...........443
EXH..246.........218..............114...........406
Part# Description Advertised Duration Duration @ .050" Gross Lift w/
1.6 int /1.8 ext
Stock Specs for D16Z6 SOHC VTEC (92-95) 304 / 303 212 / 204 394 / 373
1.6 int /1.8 ext
Stock Specs for D16Y8 SOHC VTEC (96-up) 288 / 292 218 / 204 397 / 367
Found it...thanks guys.
1 - 6 of 6 Posts
